32 v/8 crank handle extension
nwjm |
02-16-2024 @ 6:29 PM
Are the square taper measurements approximately 1/2 " on the small end, 9/16"? on the large end & a shaft diameter of 11/16" ? The taper length is about 1 1/2". I have a longer one which will have to be shortened if my measurements are correct but I need a handle with an internal taper. It,s overall length is 25 1/2.
3w2 |
02-17-2024 @ 4:11 PM
The length of an original 18-17040 starting crank extension with a four-sided taper on one end was 16 3/4". The diameter of what you have is the same as an original extention at 11/16". I'll provide the taper dimensions the next time I am at my indoor junkyard.
3w2 |
02-29-2024 @ 12:54 PM
The taper is 2 1/8" on four sides ending in a 7/16" square.
nwjm |
03-03-2024 @ 7:12 AM
Thank you. I can make my extension work. I,ll shorten the drive pin end & cross drill for the pin. Now I,ll start looking for a handle. I wonder if my longer extension could have been for a BB.
