34 Roadster cowl vent screen
Joeellsasser |
03-11-2019 @ 5:52 PM
Where can I find a cowl screen? It is triangular one with the long side being concaved to fit.
3w2 |
03-11-2019 @ 6:48 PM
I think that you would be unhappy if someone sold you a triangular screen. The original had five sides and was/is a pentagon.
MG |
03-11-2019 @ 7:48 PM
See this link > https://www.dennis-carpenter.com/en/trucks/weather-stripping/cowl-firewall/40-7002280-cowl-vent-screen-1933-34-ford
hupdoc |
03-12-2019 @ 2:10 AM
I suspect that you won't find a screen for it . It sounds like ( as I do ) you have a 1933 early 1934 cowl vent . These vents did not have a screen. Also the convex bulge in the cowl flap precludes fitting the later 1934 screen which has a straight long edge
This message was edited by hupdoc on 3-12-19 @ 12:16 PM
Joeellsasser |
03-15-2019 @ 4:49 PM
Yes, I’m sure you are correct. So for Grand National showing a screen was not standard and shouldn’t be there. A second question based on the build time what champion plugs would have been used. Thanks in advance.
1934 Ford |
03-17-2019 @ 10:46 AM
Every 1934 Ford that I've owned had a screen.
1934 Ford's since 1972
3w2 |
03-17-2019 @ 11:53 AM
The Champion 7 spark plug (40-12405-C) was released for production use on 2-20-1934. Prior to that time the Champion C-7 plug was used on V8 engines. Of the six '34s I've owned two had the carryover '33 cowl vent and therefore no screen.
This message was edited by 3w2 on 3-17-19 @ 11:57 AM
