Fuel Pump Push Rod
sarahcecelia |
03-16-2019 @ 4:05 AM
Can anybody tell me the length of a new push rod, and the worn length that makes one no good? IE the tolerance allowed before it's bad?
Regards, Steve Lee
3w2 |
03-16-2019 @ 6:53 AM
Push rod for what vehicle? There are numerous different ones for the vehicles within the Club's mandate.
TomO |
03-16-2019 @ 7:33 AM
Steve as a general rule the pushrod travel is about 1/4". A worn pushrod would show up as low fuel delivery, but you would get a small amount of fuel on each stroke. If you do the fuel delivery test that I have recommended several times, it would show up a worn pushrod.
37RAGTOPMAN |
03-16-2019 @ 12:48 PM
Intake Manifold CAST IRON or ALUMINUM ? 60 85 90 95 100 125 HP? 1937RAGTOPMAN
sarahcecelia |
03-17-2019 @ 10:02 AM
Duh! 1950 Ford sedan with V8 motor.
Regards, Steve Lee
sarahcecelia |
03-17-2019 @ 10:03 AM
cast iron 1950 V8.
Regards, Steve Lee
37RAGTOPMAN |
03-17-2019 @ 10:56 AM
HI the fuel pump rod should measure 8.87 INCH with cast iron intake, there is also a brass bushing in the engine, for guiding the push rod, see if there is any side movement, slop in the push rod, hope this helps 37RAGTOPMAN
