EFV-8 Club Forum / 1932 Ford Discussion / Changing 32 Model B to a 12 Volt System
Posted By Discussion Topic: Changing 32 Model B to a 12 Volt System
Donmil
05-16-2015 @ 11:51 AM
What are your thought about changing a 1932 Model B to a 12 volt system?
Thanks,
Don Miller
Clay City, IN
3w2
05-16-2015 @ 8:35 PM
Never felt the need to consider the change.
CharlieStephens
05-16-2015 @ 9:36 PM
The only reason I would make the change would be to be able to use the "Brite (note this is the way they spell it)" bulbs from Ron Francis Wire Works, wire-works.com, (800) 292-1940. They work great but a question might be do you really need that much light? A better question might be why are you considering the change and how do you use the car? Tell us why you are considering the change and someone might suggest a better solution than changing to 12 volts.
Charlie Stephens
