EFV-8 Club Forum / 1932 Ford Discussion / 32 ford clutch and pressure plate
Posted By Discussion Topic: 32 ford clutch and pressure plate
1933
08-24-2010 @ 6:42 PM
Can I use a 1935 Ford pressure plate on a 1932 V8. Is the throw on the clutch pedal the same.
3w2
08-24-2010 @ 10:22 PM
No, the '35 pressure plate is incompatible with a '32 flywheel. If you could find the version of the '35 flywheel that is completely flat on the clutch surface, it would probably clear the bell housing on a '32 transmission case, but the other version with a heavy lip around the outer circumference will clash with a '32 transmission case.
