EFV-8 Club Forum / 1932 Ford Discussion / Radiator
Posted By Discussion Topic: Radiator
jgzavar
10-15-2020 @ 8:28 AM
What is the best coolant or antifreeze?
CharlieStephens
10-15-2020 @ 4:19 PM
I run water soluble oil. I live in Southern California, where in general do you live?
Charlie Stephens
10-17-2020 @ 7:38 AM
Propylene glycol (Sierra, StaClean) are more friendly to the environment and less likely to cause bearing damage if it gets into the oil.
Ethylene glycol (Prestone, Zerox) are toxic to most animal life, more likely to cause bearing damage if it gets into the oil.
Ethylene glycol has a better heat transfer than propylene glycol and you need less to to get below zero freeze protection.
Google propylene glycol vs ethylene glycol antifreeze to get more specifics about both products.
