EFV-8 Club Forum / 1932 Ford Discussion / 1932 b fuel pump ?
Posted By Discussion Topic: 1932 b fuel pump ?
05-14-2020 @ 6:58 AM
I have this AC FUEL PUMP.,
Maybe it is a 32 33 34 4 cylinder Fuel pump ?
Many thanks 37Ragtopman Maine,
CharlieStephens
05-14-2020 @ 11:26 AM
Here are some pictures of the correct Model B fuel pump. Will the one you have function, sorry I can't help you with that.
Charlie Stephens
05-14-2020 @ 12:03 PM
hi Charlie Stephens
many thanks, for posting the photos,
looks like mine is a aftermarket pump with a glass bowl ,,for a different make car,?
or replacement for a 4 cylinder FORD B'C
looks like it does mount the same,.on the engine
many thanks 37RAGTOPMAN, Ludolf MAINE
This message was edited by 37RAGTOPMAN on 5-14-20 @ 2:08 PM
3w2
05-14-2020 @ 2:26 PM
The shape of operating lever is not as original (as in Charlie's photos) and the outlet and inlet are both 90 degrees off from their placement on an original '32-'34 pump.
05-15-2020 @ 5:35 AM
hi 3w2
THANKS for the information, the lever does look different to me, but seems very close
thanks 37Ragtopman
3w2
05-15-2020 @ 8:57 AM
The lever on the original rides on top of the camshaft whereas the lever on yours rides on the bottom of the camshaft. Whether there is sufficient space in the cylinder block for a lever on the bottom of the camshaft is a good question, but I'm marooned very likely many miles from the nearest '32-'34 4-cylinder block.
FAR32
06-04-2020 @ 2:51 PM
I have a new fuel pump for a Model B. It started out as something else but the only important difference was the actuating lever. I had a busted original pump. I changed out the lever so it is now a replacement for the original pump. The top section is made like a 33-36 pump but the ports are angled to match the Model B pump arrangement. It sucks and holds a vacumn and pumps and holds pressure. Asking $50 for it
