I need Part Numbers
Hrussell8750 |
06-16-2016 @ 12:46 PM
Can anyone help me find the correct part numbers for a 1940 Ford Standard, I need them for the Steering Box, The Pitman Arm and Drag Link. I have purchased Ford Parts Books, Looked on Web Sites and find a lot of different numbers for different models, but not just one set for this car. I would like to find one correct number.
ken ct. |
06-16-2016 @ 1:43 PM
Only #'s I could find are for the box 81W-3548 B and pitman arm 11A 3590 A. no listing on drag-link. Out of the Green Bible. Don't know if this helps you ?? ken ct.
Old Henry |
06-16-2016 @ 2:10 PM
Green Bible says 11Y 3306-A for drag link, steering gear box is 21A 3548-A (the 81W 3548 ken ct mentioned is for COE), and pitman arm is 11A 3590-A as ken said.
kubes40 |
06-16-2016 @ 5:12 PM
Guys, a little common sense will tell ya that a prefix of 11A is not correct for a 1940 Ford. 11A didn't start until 1941. 21A didn't start until '42. Yeah, the part(s) may very well fit the '40 but it/they won't be correct. The drag link which is extremely difficult to find is part 78-3283. One end is integral of the link. The other end has female threads. NO adjusting sleeve! Pitman arm is part 78-3590. These are fairly common - fairly easy to locate. Are you doing a proper restoration? If so, I probably have both parts if you are still in need. Mike Kubarth
Hrussell8750 |
06-18-2016 @ 9:52 AM
Mike, I am restoring to original. Items that came on car when I purchased do not give proper clearance on wish bone. Finding correct parts has been a challenge. I will use these numbers to cross check parts I have purchased. I will let you know if I need parts you say you have. Thank you for your help, Hrussell
Hrussell8750 |
06-25-2016 @ 8:32 AM
Mike let me know your price for the parts you mentioned. How to pay for them and shipping. Thank you, Harry Russell
Thank You, Harry Russell
