EFV-8 Club Forum / General Ford Discussion / 1934 ford v8 hand crank dimensions?
Posted By Discussion Topic: 1934 ford v8 hand crank dimensions?
lbford25
11-24-2015 @ 10:54 PM
Does anyone have the 1934 v8 hand crank specs? I'm trying to locate one or build one from scratch. Thanks
CharlieStephens
11-24-2015 @ 11:08 PM
I would get a copy of the 1933-1934 Ford book from the club (https://www.earlyfordv8.org/store-product-item.cfm?id=17&pid=2)
). I am sure it will be in there. Put a wanted ad here and on fordbarn.com and I am sure one will show up. I assume it is similar (or maybe identical) to the 1932. Looking at the one for a 1932 I sure would look around before I tried to make one unless you just want one that is functional.
Charlie Stephens
This message was edited by CharlieStephens on 11-24-15 @ 11:11 PM
11-26-2015 @ 3:34 AM
I believe there are change to the extension and handle from 32. I would contact Lin Stacey in Ill. (see roster) Also see the 33-34 restoration book Appendix "N"
Lin is the club expert on Ford tools and sells tools.
CharlieStephens
12-01-2015 @ 3:05 PM
You might check this one out: http://www.ebay.com/itm/ORIGINAL-FORD-LUG-CRANK-WRENCH-TOOL-1932-1933-1934-ROADSTER-CABRIOLET-COUPE-34-/131665694872?hash=item1ea7e31098:g:buwAAOSw8-tWXghC&vxp=mtr I have no idea of what is correct for a '34.
Charlie Stephens
