EFV-8 Club Forum / General Ford Discussion / T-5 TRANS ADAPTER TO FLATHEAD
Posted By Discussion Topic: T-5 TRANS ADAPTER TO FLATHEAD
100YVAT
04-05-2015 @ 8:49 AM
WHAT IS THE LATEST ON ADAPTERS AVAILABLE TO PUT A FORD OR GM T-5 TRANY TO A FLATHEAD
04-05-2015 @ 4:06 PM
I don't know the latest information about putting a T-5 Borg-Warner 5-Speed manual transmission behind a Ford Flathead V-8. What worked for me with a 1937 V8-60 was buying an adapter bellhousing from Cornhusker Rod & Custom in NE, a custom 9" Ford clutch disc with 14 spline (Chevy type) hub from Speedway, a custom pilot bearing from Speedway, and a 1986 Chevy S-10 type of T-5 with the mechanical speedometer drive. The other small parts I needed to complete the installation came from The Gear Box Transmissions in MI.
jackb
04-06-2015 @ 4:48 PM
vanpeltsales.com
This guy has everything you need and all the information too.
Good luck Jack
