EFV-8 Club Forum / General Ford Discussion / What year engine do I have?
Posted By Discussion Topic: What year engine do I have? -- page: 1 2
ellsworth
12-08-2011 @ 11:21 AM
I have a 36 ford 5 window coupe. I'm sure the engine is not a 36 because it used differant size spark plugs.
How can the year be determined?
Ellsworth
alanwoodieman
12-08-2011 @ 12:28 PM
take a picture and post it for starters, how many bolts or nuts are holding a head on ?,are there any numbers/letters on the heads ? , where are the water outlets on the heads-in the top middle-to the front, where are the water pumps-in the heads -down in front of the block?, all are questions to help determine the approx. year of your motor and sometimes a specific year is hard to determine
CharlieStephens
12-08-2011 @ 2:06 PM
Identification of the early flatheads is best approached in terms of the block. There is an unbelievable amount of interchangeability for the accessories over the years. Count the number of head studs.
1) If there are 17 studs it is a V8 60 used in vehicles between 1937 and 1940. This engine was also used in the French built Simca in the sixties but I don’t know what occurred between these two periods. Look for casting numbers and stamped steel water jackets in the side of the block. Post what you find and someone can probably further identify the engine.
2) If there are 21 studs the block was built 1932 to 1938. The transition to 24 studs was late in 1938. Check the water petcocks on the front of the block next to where the lower hose from the radiator enters either an inlet fitting (1936 and earlier) or the water pump (1937 and later). It the petcocks point straight down it is a 1932 block. If the block is not a 1932 next look for a vent from the crankcase area out through the front corner of the oil pan. If there is no vent the block is 1933-34. If there is a vent it is 1935 or later. As a matter of interest, the 1936 engines were the first to use insert bearings. Both insert and babbitt bearings were used throughout 1936. The insert bearing engines can be identified by LB cast at the top of the left front face of the block or by the letters LB stamped into the surface where the intake manifold attaches. Some engines were not stamped and in other cases people tried to inflate the price of their blocks by stamping LB into them when they were sold. Be careful. Now check for the location of the water pumps. If the water pumps mount on the block the engine is 1937 or later. All engines beginning in 1937 were inserts. Frequently you will encounter a 1937 block with factory block off plates held on by two bolts over the water pump passage at the front of the block as it was common for Ford dealers to install this engine as a replacement in the earlier cars. Of course there will be slight transition periods at model change over with the older blocks usually going into the commercial vehicles. There may be subtle differences between the 1933-34 and the 1935-36 engines but I am knowledgeable enough about these years to know what they are. The casting numbers on the flywheel housing will also help identify the exact year of the engine. Post what you find and someone can probably further identify the engine.
3) If there are 24 studs the engine was produced between late 1938 and 1953 (1954 in Canada). If the distributor is mounted on the front of the block the engine is late 1938 through 1948 (1947 for trucks). If the distributor comes up at an angle and appears more like a modern distributor it is a 1949 (1948 for truck) through 1953 (1954 in Canada). The casting numbers on the flywheel housing will further identify the exact year of the engine. Post what you find and someone can probably further identify the engine.
4) There are a lot of additional foreign and industrial applications of these engines but the preceding covers the domestic US automobile production.
Stroker
12-08-2011 @ 2:36 PM
Charlie; you really NAILED-IT! That's a keeper. I was trying to write something similar, and then request a photo like Alan, but you definitely covered the bases. Now, maybe you can answer
the spark plug question, as I can't.
Ellsworth: We'd really like a photo, though.
Dan
CharlieStephens
12-08-2011 @ 4:01 PM
I can't answer the spark plug question. Could be right engine wrong heads, wrong engine with right heads for that engine. Picture will tell.
Charlie Stephens
1934 Ford
12-11-2011 @ 4:30 AM
Great write up Charlie!
Other than 1932, don't all the 21 stud engines take the same replacement plug for the C-7 (Champion D-16 or Autolite 386) plug with a 18 thread? (Sold as lawn mower and equipment plugs at parts stores)
ford38v8
12-11-2011 @ 9:15 AM
Charlie, as with heads that may have been replaced, isn't it true that petcocks may have been replaced? Both can be indicators, but bolt-ons can be decieving.
CharlieStephens
12-11-2011 @ 4:54 PM
I am not sure what you mean about the petcocks. If it was my reference to them being vertical in '32 that was because the hole was drilled and tapped vertical in the block in '32 only.
Charlie Stephens
CharlieStephens
Charlie Stephens
CharlieStephens
12-11-2011 @ 5:03 PM
deleted duplicate post
This message was edited by CharlieStephens on 12-11-11 @ 6:48 PM
