Radiator Mounts
Steves46 |
07-09-2011 @ 1:19 PM
When I re-installed my refurbished radiator in my 46 Coupe, although I have the bolts and springs, it did not have the rubber piece that I see in the replacement installation kits. Will I be ok without this rubber piece or would it be a good idea to get them?
ford38v8 |
07-09-2011 @ 1:39 PM
Steve, it'll be ok, but it might squeek. The frame is not rigid, but the radiator needs some wiggle room. Same for the gas tank, but no rubber on gthat mount.
supereal |
07-09-2011 @ 3:31 PM
The purpose of the rubber pads is to reduce or eliminate any squeaking as the radiator moves on the springs. We usually just cut a couple of strips of rubber from an inner tube. In all, it isn't a vital component such as the springs, and not worth redoing the job.
