Carburetor for 1939 Ford
gdornfeld |
08-25-2010 @ 2:07 PM
I know this has been presented before, but my tech data is with my car in Florida, and I am in Ma. I need to know the correct carburetor for the 1939 Ford. I have several in my stash, but want to bring the correct model down to Fl.
kubes40 |
08-25-2010 @ 3:24 PM
I am guessing you are asking about the 85 H.P. application? If so: Many folks may tell you the Chandler - Groves carburetor is correct for '39. However, in reality it was phased out in late 1938. The correct carburetor was made by Ford in their Milford Village Plant as well as Holley. Both carburetors will have (on one side of the fuel bowl) "Ford" in script. On the opposite side is Model 91-99. The Ford manufactured carb. will have a small "F" on the accelerator pump housing. The Holley produced carb. will instead, have a small "H" in that same place. Both carbs. will have an elongated vent hole in the top cover. Both will have "94" within a circle on the back of the carb. I can send you detailed photos if desired. Hope this helps. Mike Kubarth
supereal |
08-25-2010 @ 4:14 PM
Mike: Wasn't the "92" (922) carb also used '37-'40?
kubes40 |
08-25-2010 @ 5:25 PM
Hey Super, The model 92 was only used on the 60 H.P. engines.
supereal |
08-25-2010 @ 6:56 PM
Thanks for the correction. That is why I don't have one in my pile of old carbs!
ford38v8 |
08-25-2010 @ 7:19 PM
Mike, You are correct about the Chandler Groves without model number, as it and the Stromberg 97 were not used beyond the '38 model year. However, the Chandler Groves having the 91-99 model number is correct for the '39 Ford and Mercury, along with the Ford and Holley 91-99's.
gdornfeld |
08-26-2010 @ 7:16 AM
Thanks; that is exactly what I needed.
40 Coupe |
08-26-2010 @ 10:45 AM
According to the 38 39 restoration book the Chandler Groves Co.designened the CG carb and it carried their name and patent numbers but it was made by Holley and it carried the "H". There is no mention of any of the CG carbs also being marked 91-99. The book does say the left side of the carb is blank.
kubes40 |
08-26-2010 @ 11:50 AM
That's true... the C-G carb that had their name, etc. on the side was utilized throughout '38 and I suppose no doubt a bit into 39. However, in '39 Ford got away from C-D as a supplier and went in house as well as to Holley for their carburetors. The carbs then produced by Holley, even though a C-D design had no other identifiers than "H".
This message was edited by kubes40 on 8-26-10 @ 11:51 AM
ford38v8 |
08-26-2010 @ 1:16 PM
With regard to the markings on the 94 carburetors: All 1938 94's were marked Chandler Groves. Markings for 1939 were either Chandler Groves or Ford script. 1938 94's had no model numbers. All 1939 94's were marked 91-99. Some of both years were marked F or H. All of both years were marked 94 and 15/16. Early 91-99's had that number etched into the molds. Late 91-99 molds utilized a replaceable "coin" model number insert. It has not been established that "coin" 91-99's were service replacements. All 94 bowl castings were identical but for markings, and interchangeable up to 1948. Air horn castings differed only in the evolution of bowl vents and air cleaner requirements.
