EFV-8 Club Forum / General Ford Discussion / Oil pressure gauge connections
Posted By Discussion Topic: Oil pressure gauge connections
Fordfan1
04-10-2024 @ 1:39 PM
Connecting the wires to the oil pressure gauge on my 35, ignition switch wire to the top terminal sending unit wire to the bottom or-???
OK let me rephrase this the gauge is installed in the dash it has two terminals one above the other which there are two wires going to the gauge a yellow with black tracer from the sending unit the other is black with a green tracer the 6 volt feed which wire goes to which terminal-?
Thanks'
Mike
This message was edited by Fordfan1 on 4-12-24 @ 10:02 AM
04-11-2024 @ 6:34 AM
The ignition switch has no wires to the oil pressure gauge or it's sending unit. The sending unit has just one electrical terminal on it's top.
