EFV-8 Club Forum / General Ford Discussion / 1939 ford standard car
Posted By Discussion Topic: 1939 ford standard car
william
08-08-2022 @ 3:22 PM
I guy's I'm new to this V 8 Ford stuff . I have a 1938 5 w/coupe that I changed over to the hyd brakes . ( I copied from a 1940 coupe ) But here is the question ? I also have a 1938 tudor sedan that I bought converted with mustang 11 front axle with disk brakes and I think falcon rear end has 8" diff. anyway with wheel cylinders . The gent before used a ford 1939 or 40 ? brake mounting braket .The master cylinder went bad and it stuck up above the floor 1 1/2" under my foot . It was a new style ford two bowl, I was going to put a 1939 ford master cylinder in it's place , which would not be sticking up above the floor . Here's the main question . I bought a new 1939-48 ford master cylinder , and the seller came back and said 1939 ford standard cars did not have hyd brakes ,they were still mechanical and didn't want to sell me the master cylinder . Is this true ?? I thought all 1939 cars came out with hyd .?
08-08-2022 @ 5:43 PM
All 1939 Fords had hydraulic brakes. The only possible explanation for a 1939 Model Year vehicle to have mechanical brakes would be for it to have been a retitled 1938 MY vehicle.
1931 Flamingo
08-09-2022 @ 6:40 AM
Find somebody else to sell you a m/cyl BUT I don't think an original m/cyl is going to work with the disc brakes.
Mosey over to the HAMB and they'll "fix" you up with what you need.
Paul in CT
08-09-2022 @ 7:21 AM
Is there an adapter on the pedal bracket for the later two bolt master cylinder? If you use the '39-40 pedal assembly there is an adapter that bolts to this assembly to use the later two bolt master cylinder. The adapter is sold by Chassis Engineering company. Then use a master cylinder from a 70's/80's Corvette. Chassis Engineering may also carry that MC. I have used this combo before and it all stays under the floor. You will also need to put a 2 lb residual valve in the front line and 10 lb residual valve in the rear line. CE may also have these residual valves plus the necessary proportioning valve.
william
08-16-2022 @ 10:11 AM
Thanks for your reply . I was on the same page as you . I don't clame to know it all , but that was my thought also .
william
08-16-2022 @ 10:33 AM
Thanks for the reply . I ended up telling him I wanted to replace a 91A-2140 master cykinder . and he sent it . I'm sure you are right about using the 39 master cylinder with disc brakes . I done away with the newer ford master cylinder with two bowls because it stuck up above the floor about 1 1/2" right under my feet and it went bad . So I went to a GM style that is almost even with the floor . The conversion was done before I bought the car . This is on a 1938 Ford tudor sedan standard . And it has the 350 chevy engine with auto trans . I do have a 1938 Ford 5 w/coupe and I did put 1939 hyd. brakes on it .So I have a spare master cylinder for it .
Bill
william
08-16-2022 @ 10:46 AM
Thank you for the reply . As for the 1939 standard not having hyd. brakes , that the seller told me didn't have hyd. . The club says if only a 1938 was titled as 1939 . I have this setup on my car now that you have described with the GM master cylinder with the two residual valves . And the master cylinder is almost flush with the floor .
Bill
supereal
08-20-2022 @ 11:53 AM
The system should have a proportioning valve to adjust the action of the front and rear brakes. Beware of any "home brew"
brake modifications. They are suspect, as the brake systems on any vehicle are carefully engineered for safety.
supereal
08-24-2022 @ 12:15 PM
When Henry Ford was presented with a new 1939 model. he demanded that the hydraulic brakes be removed and mechanical brakes be installed. He wanted "all steel from pedal to wheel" as he considered hydraulic brakes dangerous, even though they were a safety improvement over the rod system, and the often troubling "cable brakes" which required frequent attention to assure reliable stopping.
jeremiahquellette
11-06-2022 @ 3:45 AM
A wooden stick is an option. However, you can weld a folding tube there.
