Banj0 steering wheel horn button
1934 Ford |
11-26-2020 @ 8:18 AM
I have a nice 36 Ford Banjo steering wheel that I would like to put on my 1934 Fordor. Question is: What horn button fits that steering wheel? Will my stock 34 one work? 1934 Ford's since 1972
This message was edited by 1934 Ford on 11-27-20 @ 9:39 AM
40 Coupe |
11-28-2020 @ 4:48 AM
The 35-36 horn button is about the largest in diameter. 34 is too small. I have no idea about the length if you plan to use the original light switch and horn button and have them function. Take a look at the classified ads and you can see how large the 35-6 horn button is.
This message was edited by 40 Coupe on 11-28-20 @ 4:51 AM
37RAGTOPMAN |
11-29-2020 @ 6:12 AM
you will have to check the length of your 34 Lightswitch rod,to a 1936 Lightswitch rod, they may be the same, if the same, this is not as easy as you think, to remove the lightswitch rod, you may have to drop the steering column to pull the lightswitch rod out, or it may hit the roof of closed cars, bending the rod is not a good thing, once you have the rod out, you still have to remove the steering wheel, sometimes this is difficult ,also good luck , hope this helps, 37 Ragtopman
