EFV-8 Club Forum / General Ford Discussion / 3rd brush
Posted By Discussion Topic: 3rd brush
fatdog
06-05-2020 @ 7:35 PM
hi all, need some help. my generator in my 37 is only charging 6V. I tried moving the 3rd brush in both directions with no increase or decrease in voltage. Any ideas ???????
thanks
06-06-2020 @ 6:09 AM
hi 3rd brush
did this happen all of a sudden, HOW is the cutout, it should kick in at high idle, maybe stuck open
what does the ammeter read, ? not moving maybe it is defective, try a hand held volt amp meter to check the electric system. you might have a loose or dirty connection along the way,
never rely on a original ammeter it is a gauge not a instrument,
is this with the lights on ? and at idle ?
what happens when you increase the rpm.
the generator should start to increase the voltage when speed is increased,
if you have the original owners manual, it does have instructions ,
if the commutator is dirty, does the generator spark while it is running at high idle ?
brushes worn down ?
if you can clean the commutator with very fine sand paper on stick [while idling ,BECAREFULL ]
gluing the paper to the stick. , till commutator is shiny copper,
and a spray can of electric motive cleaner,
this might help. hope this helps, 1937 Ragtopman
CERTIFIED AUTO ELECTRIC in OHIO rebuilds generators and starters if you have any problems
