EFV-8 Club Forum / General Ford Discussion / starter
Posted By Discussion Topic: starter
JohnA
10-20-2018 @ 12:25 PM
Whats causing my starter on my 239 flathead to have flat spots or dead spots where it will just spin and not engage flywheel,maybe flywheel problem or starter problem,and whats fix.Tks johna
cliftford
10-20-2018 @ 6:40 PM
If it just spins I would guess a bad or sticky Bendix drive. If it grinds I would suspect bad or missing teeth on the flywheel
cliftford
10-20-2018 @ 6:41 PM
JohnA
10-20-2018 @ 6:46 PM
cliff,would I just clean up Bendix with solvent??
skinnedknuckles
10-20-2018 @ 6:51 PM
Having starter problems with my “new to me” ‘37 Ford, 60 HP.
The Bendix is hit and miss. If Bendix engages properly the engine
starts immediately.
Pulled the starter today and will take it to Gen-Star in Glendale, AZ.
for inspection and rebuild. Out of the car, the Bendix travels
smoothly on the output shaft.
What’s your take.... weak starter and/or bad Bendix?
cliftford
10-20-2018 @ 9:25 PM
To answer your question, yes that would be a good place to start, and check the overall condition 0f the Bendix. If you are not hearing any grinding, the flywheel teeth are probably ok.
JohnA
10-21-2018 @ 6:05 AM
10-4,Cliff
