EFV-8 Club Forum / General Ford Discussion / 1951 F1 oil pump
Posted By Discussion Topic: 1951 F1 oil pump
PeterFord
08-21-2018 @ 4:17 PM
What is the torque to be applied when tightening the single bolt that holds the pump in place? Also, the new Bob Drake pump comes with two bolts to attach the pick-up unit. The two bolts are of different lengths, as are the two on the original pump. The holes they go into are of equal depth. Why are they different?
08-22-2018 @ 7:01 AM
The oil pump to block bolt is torqed to 12-15 Ft lbs on the V-8 engine. The bolts that hold the pickup tp the body on the V-8 engine are both 1/4"-28 x 5/8".
