EFV-8 Club Forum / General Ford Discussion / wheel pcd
Posted By Discussion Topic: wheel pcd
36coupe
04-15-2010 @ 8:58 AM
will a ford pilot wheel fit a 1936 coupe? thanks
Colin
04-15-2010 @ 11:18 AM
The road wheel for the English Ford V8 Pilot (1947-51) is part number 68-1015-A which is a 1936 part number and to my understanding will fit a 1936 Model 68. The same wheel will also fit the Lincoln-Zephyr 1936, 1937 and 1938 except very late production cars. Hope this is useful to you. If it helps I have some of these wheels if you need any and I am in England.
lightflyer1
04-15-2010 @ 12:14 PM
One post will do. Wait at least 24 hours for an answer.
47Fordor
04-15-2010 @ 6:30 PM
lightflyer1: I'm sure he didn't intentionally post three times. Sometimes it seems like there is an echo on this page. I've had several times when, for no aparent reason, my post showed up at least twice.
Chris
04-16-2010 @ 6:23 AM
Be Sure to Measure the how wide the wheel is,
I know for a fact, that 1937 85 hp wheels are wider then the 60 hp wheels and take a different size tire,
I would assume you could use the wider wheels, if you used on all 4 , and used the wider tires,600x16
the narrow wheels used the 5.50 x 16 tire.
hope this helps,37RAGTOPMAN
