EFV-8 Club Forum / General Ford Discussion / Oil pump relief valve
Posted By Discussion Topic: Oil pump relief valve
MOXIE
04-05-2010 @ 5:36 PM
The oil relief valve plunger is held in place by the oil relief valve threaded plug. Is there suppose to be a gasket between the oil relief valve threaded plug and where it screws into the block. I thought I kept up with the parts when I removed them, but I could have lost the gasket.
04-06-2010 @ 8:11 AM
There is no gasket for the V-8 engine. The 6 cylinder engine uses a gasket.
