EFV-8 Club Forum / General Ford Discussion / 1936 front spring
Posted By Discussion Topic: 1936 front spring
flatheadfan
09-22-2016 @ 10:01 AM
I have a '36 front spring. The spring bundle is held together with a long bolt with a square head. The square heat fits into a square "slot" in the cross member. The only way this fits is everything must be in perfect alignment. As you probably know it isn't easy to hold the spring bundle up and hope everything fits.
I have a spring bolt (possible Model A) that has a round button head. It seems that his would be a lot easier to fit into the cross member slot that an square head. Would a round head work as well as a square head in aligning the spring???
ken ct.
09-22-2016 @ 11:55 AM
lay the spring on a floor jack and go to work on it. ken ct
09-23-2016 @ 6:51 AM
The round head will work. I have used them in the past with no problems.
flatheadfan
09-23-2016 @ 11:15 PM
Thanks guys for the help.
