EFV-8 Club Forum / Light Commercial Truck Discussion / 33 pickup rear wheel bearing surface
Posted By Discussion Topic: 33 pickup rear wheel bearing surface
33pickup
10-11-2014 @ 12:00 PM
The rear wheel bearing surface on the housings of my '33 pickup is worn and have some rust. I need to find the correct measurement to see if I can recover the housings.
alanwoodieman
10-11-2014 @ 4:40 PM
you can purchase bearing sleeves to have any machine shop install for you-requires machine work. the problem is sourcing decent replacement sleeves-someone will give the cource for the best sleeves-the last ones I used were not the good ones!!
