EFV-8 Club Forum / Light Commercial Truck Discussion / Key tumbler removal?
Posted By Discussion Topic: Key tumbler removal?
Jeepbut
07-28-2022 @ 7:29 PM
How do you remove the key tumbler? Previous owner drilled out where the key is. Currently has a small wrench stuck in the column to keep the rod from locking the steering column. I would like to remove the rod that locks the steering column. I can get it to move but the toggle switch moves up slightly and stops. How can I remove the toggle swicth? Has switch moved to dash and switch behind toggle switch is removed already. Thanks.
07-29-2022 @ 7:35 AM
There's a pin on the underside to the column bracket. It's just below the lock cylinder. The pin needs to be drilled out or you can use a small drill and then a slide hammer to pull out the pin.
Jeepbut
07-29-2022 @ 2:24 PM
I think I described the wrong thing. The key tumbler is already out. I need instructions on getting the locking mechanism out. I need to remove the rod that locks the steering column. It's the one that the on/off switch goes through. It needs to come upward out of the column. Thanks.
rustedorrotting
07-30-2022 @ 10:23 AM
I just went through this on my 41 1/2 ton. My truck is a very rare 3 on the column and of course the switches are not the same. If you send me a picture maybe i can help. I had to hand make some of the pieces.
Jeepbut
07-31-2022 @ 4:02 PM
Figured it out. Thanks.
