Radiator
bobmg53 |
01-15-2022 @ 7:20 AM
Anyone put an 2003 5.3 in a 38 p/u. What radiator did you use?
1931 Flamingo |
01-16-2022 @ 7:00 AM
You might be better off asking this question on the HAMB or FordBarn. FWIW Paul in CT
zeke3 |
01-16-2022 @ 6:54 PM
Back in the 60's I put a 289 in a 1937 passenger car and reused the existing radiator with one inlet and one outlet removed. We never had any cooling issues with that combination.
trjford8 |
01-18-2022 @ 9:04 AM
Check with U.S. Radiator they have aluminum or copper/brass radiators and can put the correct inlet and outlet on the radiator. If you are using a late Ford motor you need to tell them which side the water pump mates to the radiator. Ford had several different pumps.
