EFV-8 Club Forum / Light Commercial Truck Discussion / Gauge and toggle switch questions?
Posted By Discussion Topic: Gauge and toggle switch questions?
Jeepbut
01-04-2021 @ 4:34 AM
Temp gauge is pegged out on hot with or without power. With key on, test light shows power only on one terminal where as other gauges show power on both terminals. Is temp gauge shot? Also, there is a toggle switch under side of dash approximately below starter button. What is it?
alanwoodieman
01-05-2021 @ 6:18 PM
toggle switch is dash lights, check to see if the sending unit wire is connected for temp gauge, gauge should read hot with switch off, then go to cold, maybe the sender has shorted out. remove wire from sender and see what gauge shows
Jeepbut
01-05-2021 @ 6:49 PM
Thanks, I'll check it out this weekend.
alanwoodieman
01-06-2021 @ 5:25 AM
get some one to watch gauge and with power on ground out the sender wire momentarily to see if gauge moves then sender is bad, if gauge does not move then it is bad
Jeepbut
01-07-2021 @ 3:59 AM
Thank you
01-07-2021 @ 7:27 AM
I connect the sender wire to ground and then turn on the ignition switch until I can see needle movement, about 30 seconds.
