EFV-8 Club Forum / Light Commercial Truck Discussion / 1933 ford pickup light switch
Posted By Discussion Topic: 1933 ford pickup light switch
yogiyost
08-28-2020 @ 5:11 PM
A good friend recently gave me his 33 ford pickup with the B engine -- not a beauty but runs great-- under the hood, the headlight and other wiring is a mess of splices made with large wads of solder covered bt masking tape! I removed the switch box on the bottom of the steering box only to find it FULL of grease/oil-- need to figure out where this oil came from so can repair the leak and rewire with the recently purchased new switch box, etc, and new wiring harness-- trying to find out how to replace the cork gasket that apprears to be the channel of the leaking oil-- any help, advice, or guidance will be greatly appreciated!! Thanks! Bob
1931 Flamingo
08-29-2020 @ 5:02 AM
That oily mess is the steering box leaking. The vendors have a replacement bottom plate with a tube attached that when installed on the bottom of the gear box (with a new cork gasket) brings the tube above the level in the gear box. Then add PennRite steering box lube= No Leakee.
Paul in CT
yogiyost
08-29-2020 @ 8:16 AM
thanks!! I'll seach for the part!! Can you suggest a source? Bob
1931 Flamingo
08-30-2020 @ 12:19 PM
Most A vendors carry it: Snyder's, Bratton's, Tams and probably Bert's in Denver.
Paul in CT
yogiyost
09-02-2020 @ 11:44 AM
Thanks again for the help! Looks like I have a 2-tooth box- ordered the "tube" and a new steering housing end-plate-- I have several cork washers, however do not find the steering oil seal retainer -- Bob
09-02-2020 @ 3:12 PM
Check with Michael at Third Gen Automotive or C and G Parts. Both are listed in our links/vendors section on this site.
