EFV-8 Club Forum / Light Commercial Truck Discussion / 1946 Wheel help
Posted By Discussion Topic: 1946 Wheel help
BBartoli
08-03-2020 @ 8:04 PM
I am looking to upgrade to a more modern tire set up. I have some 15x6 rims on it now with p215/75r15 tires. Can I go up to a 15x7 rim and not have any issues with clearance ?
1946 Ford 1/2 ton Pickup
08-08-2020 @ 7:53 AM
If you have the stock rear end you should be able to use a 15X7 wheel on the back depending on the back spacing. You will also have enough room to run a tire as big as a 235X75 tire.
