EFV-8 Club Forum / Light Commercial Truck Discussion / 51 F 2 CLUTCH
Posted By Discussion Topic: 51 F 2 CLUTCH
caddy40
09-21-2019 @ 8:42 AM
I recently purchased a clutch repair kit from Ecklers. The clutch has been installed by a transmission /clutch shop. i still cannot shift without grinding trans teeth. I am taking the truck back to the shop on Tuesday. wondering what might be the probable cause. Any ideas ?
alanwoodieman
09-21-2019 @ 12:52 PM
not adjusted properly. do you have a 4 spd? or a HD 3 spd?
caddy40
09-22-2019 @ 10:51 AM
It is a 5 speed plus reverse.
09-22-2019 @ 10:55 AM
sounds to me the clutch is not completely disengaged when depressed, some dragging, between the flywheel and pressure plate,
make sure you have enough free play travel in the clutch pedal,does pedal work smooth ?
if you have the 4 speed truck transmission you might have to double clutch when shifting,
try double shifting, and see if it shifts better
its like driving a MODEL A
good luck.
hope this helps, 37Ragtopman
caddy40
09-22-2019 @ 2:12 PM
Thanks, I will talk to the mechanic about this on Tuesday.
