Banjo Axles
dladrigan |
03-03-2019 @ 6:42 AM
Can I change just the axles and housings from a 39' Ford to the center section of a 42' Ford? Thanks for any help
Flatties Forever
ford38v8 |
03-03-2019 @ 10:16 AM
It can be done, but you'd also need the spring, tube shock mounts, a shorter sway bar, wheel spacers, modified radius rods, and a host of other considerations like hand brake cable. Best to do right with the correct and plentiful '42 - '48 axles. Alan PS - I just now discovered that you are working with a pickup. My advice given was for a car.
This message was edited by ford38v8 on 3-3-19 @ 10:24 AM
alanwoodieman |
03-03-2019 @ 1:01 PM
what year car/truck will you be using it under?
