EFV-8 Club Forum / General Mercury Discussion / 49 Mercury Carb Flooding
Posted By Discussion Topic: 49 Mercury Carb Flooding -- page: 1 2 3
zoopie36
05-29-2016 @ 7:45 PM
I have been running my 49 Merc with original flathead and original carb. Then the other day I started it up and it ran fine for a few seconds and then started to miss. Gas was coming out the side. I took out the needle valve and cleaned it. Put it back together and still has the same problem. Any help would be greatly appreciated. Thanks, zoopie
cliftford
05-29-2016 @ 7:50 PM
Pull out the float and check it for leaks, and for free movement in the bowl .
zoopie36
05-29-2016 @ 7:57 PM
I did do those. Had no leaks and moved freely. Thanks
cliftford
05-30-2016 @ 7:04 AM
It sounds like fuel is getting around the needle and seat, maybe due due to looseness , a bad seat gasket, or a crack on the carb. body.
05-30-2016 @ 7:14 AM
Did you place the float in a pan of boiling hot water?
To do this, boil some water in a pan deep enough to submerge the float. Once the water starts to boil, turn off the heat and submerge the float in the water. If you float is leaking, you will see a stream of air bubbles come from the leak.
Clean the area around the leak with steel wool or sand paper, get some plumbers solder with tinning compound and flux and apply heat to solder it closed. Recheck the float, as this process can open up new areas. Use as little solder as possible.
You may be able to find a good used one as I don't think that those Holley floats are reproduced.
ken ct.
05-30-2016 @ 8:07 AM
I have some Merc floats if you need $10 each plus $7 mailing in small flat rate box. Have many rebuilding parts for the Merc back draft carbs. ken ct. email, pm or cell 1-203-260-5945.
zoopie36
05-30-2016 @ 6:34 PM
Hi Tom, Thanks for the info. I will try that boiling method but when I take off the top bowl, the float is setting exactly where it should be on top of the gas. Would it do that if it had any holes? Dale
05-31-2016 @ 7:00 AM
Dale,
You are probably correct that it isn't the float, but I would still check it to eliminate the possibility.
Exactly where is the fuel leaking from? Make sure that it is not coming from the inlet fitting.
ken ct.
05-31-2016 @ 7:35 AM
Do not get to a near boil as you will get bubbles rising from the bottom of pan to confuse you. Just get good and hot. Merc. inlet fittings are notorious for leaking. Their are 2 types of inlet threads some have 1/8" PT and some have a bigger hole with straight thread and very fine thread and is used with a gasket an fitting. Top cover MUST go on correctly . ken ct.
zoopie36
06-01-2016 @ 3:08 PM
Tom, I start the car and its runs smoothly for a few seconds until it starts to miss due to the flooding. I shut off the motor and look under the hood and the carburetor is leaking gas through the accelerator pump hole. When I take the top off, the carb is full and the float is up to where it should be. zoopie
PAGE: 1 2 3
