EFV-8 Club Forum / General Mercury Discussion / Voltage regulator
Posted By Discussion Topic: Voltage regulator
jerandbee
05-13-2014 @ 12:06 PM
My 1940 Mercury has a repro voltage regulator - club members have said that the original had a left side ground terminal. Can this style regulator still be purchased and if so where?
Thank you to you all for your assistance in each of my questions.
05-14-2014 @ 9:15 AM
The original voltage regulator had a cadmium plated cover that was marked ARM, FIELD and BAT with a side terminal for the ground. It is mounted on 3 cushions that are being reproduced. The regulator is not being reproduced at this time to my knowledge, so you will have to try to find a used one and restore it.
Here is a photo of one.
jerandbee
05-14-2014 @ 3:55 PM
Thank you - great photo that I can use at swap meets, etc.
