EFV-8 Club Forum / General Mercury Discussion / Access cover plate door - 53' Merc
Posted By Discussion Topic: Access cover plate door - 53' Merc
Merc Cruzer
04-09-2014 @ 7:23 AM
Does anyone have a picture of the cover plate that is mounted over this opening in the door? Should be the same for Ford and Mercury 52-53.
04-10-2014 @ 7:44 AM
I have the drawing in the Lincoln Body Parts manual and the drawing in the Lincoln - Mercury Repair and Adjusting manual. Unfortunately there is no way to get dimensions.
The cover overlaps the hole and is recessed in the hole area. If you would like me to, I can post the body parts catalog drawing.
Merc Cruzer
04-10-2014 @ 2:12 PM
If you want my e-mail address is royd13483@aol.com. If you could send the pictures that would be great.The one here is from the 52' Mercury body book but it is for a 4 door, and smaller. The two doors and covertibles were bigger holes.
04-11-2014 @ 6:50 AM
The drawing in the Body parts book is very similar to the drawing that you posted. It is also for a 4-door.
Are you looking for a cover to use as a pattern to make one for your car? The drawings will not help as they are not to scale. You could try the Archives at the Henry Ford for an engineering drawing with the dimensions.
Merc Cruzer
04-11-2014 @ 7:46 PM
TomO:
Yes I am looking for a picture that I can get the measurements from and then reverse engineer the cover. Ideally I would like to get my hands on at least a piece of one to then look for a similar material made today.I wouold guess very simular to the material used for the trunk inserts.
Merc Cruzer
04-13-2014 @ 1:12 PM
Template
Merc Cruzer
Origional cover
Merc Cruzer
04-13-2014 @ 1:13 PM
Installed
