rear flipper window rubber weather strips
Chascwell2 |
02-17-2014 @ 10:54 AM
I have a 1940 Mercury 4 door sedan. Somewhere there are new rubber weather strips available for rear 1/4 flipper side windows. Steele, Metro, and a number of parts house do not have anything that will work. Anyone have any ideas?
TomO |
02-19-2014 @ 7:44 PM
Call Metro and talk to them about making your own. The used to have a write up available that described making the seals using 2 of their extrusions.
oldguy |
10-07-2014 @ 1:37 PM
I went to Steele and others as Tom suggested and more or less was told to you know what. what I did was ordered from C&G, three different rear seals and found that the seal for a 41 Merc (51A-773540-S) came the closest to fitting except one side was too long, after measuring (TWICE), I cut approx. 2" out of the front vertical section a little at a time ,as not to over cut, making sure it fit, then glued the joint. If you don't look too close you would not be able to tell. tried to add more pics.
This message was edited by oldguy on 10-7-14 @ 1:45 PM
TomO |
10-08-2014 @ 8:13 AM
Oldguy You did a great job on fitting the 41-48 seal into your 40 Merc. That is a great tip and should be submitted to the V-8 Times "It Worked For Me" section. Mr Windle is always looking for items for this section. You must post each photo in a separate post.
Chascwell2 |
11-21-2014 @ 4:16 PM
I hunted all over for new rear quarter window rubbers for my 1940 Mercury four door sedan. Then I found out that the 1940 Ford rubbers were the same, they fit perfect. Not true for the front door wing windows however. Using 1940 Ford rubbers, it was necessary to cut and fit.
chascwell
Ilvi |
01-20-2015 @ 10:32 PM
DISCLAIMER: The V-8 Club does no independent testing of any of the opinions, thoughts or suggestions presented in the website on the Forum, in the Tech Tips section, or any section. A reader should consider the website to be a forum wherein differing solutions to a particular set of circumstances may be discussed. Ultimately, the selection of an item for an individual's vehicle must be based upon the independent study of the vehicle owner in consultation with people in the hobby and restoration experts. Testking Pass4sure SY0-401 210-260 300-209 70-341 1z0-808 156-915.77 ACMA_6.1 C4040-250 700-001 1z0-425
This message was edited by Ilvi on 1-23-16 @ 5:35 AM
