EFV-8 Club Forum / General Mercury Discussion / Rear window motor test - 4 wire motor
Posted By Discussion Topic: Rear window motor test - 4 wire motor -- page: 1 2
Merc Cruzer
01-27-2014 @ 8:26 PM
I want to test the motor (6V) on a 6 volt battery. The 4 leads are red, black, white and green.
Black to pos (+)
Red to neg (-)
White to ?
Green to ?
01-28-2014 @ 9:14 AM
The best way to test the motor is to hook it up to the relay and switch for window motor switch.
If you do not have a switch and relay you will have to use trial and error to find out which wires need to be connected together.
The wires should be color coded black, red,yellow and green.
The black wire goes to ground, red and yellow are probably the brush wires and green is the other field wire.
Check this out with an ohm meter, the meter connected to the black and green wires should read around 0 ohms and not change when the motor is turned by hand, The meter connected to the red and yellow wires should read around 0 ohms but it will fluctuate when the motor is turned by hand.
If the above readings are what you have, connect the yellow and red leads together and the green lead to the neg battery terminal and the black wire to the pos terminal. The motor should run in one direction.
If the readings are different, you will have to determine which wires go to the field and wich go to the armature or brushes.
Merc Cruzer
01-28-2014 @ 3:26 PM
Tom:
Thank you that did work. I do have the relays but I wanted to be able to bench test a motor without having to pull the back seat out of the car. I have been known to cary a 6V battery to swap meets just to check items before purchase. Since that rotated the motor in one direction is there a way to get it to turn in the other direction?
Thank you again,
Roy
This message was edited by Merc Cruzer on 1-28-14 @ 3:32 PM
01-29-2014 @ 6:51 AM
Try swapping the yellow and red wires. That should reverse the motor.
What year Mercury are you working on?
This message was edited by TomO on 1-29-14 @ 6:52 AM
Merc Cruzer
01-29-2014 @ 7:49 AM
Roy:
The motor is not a permanent magnet motor and is not polarized. I must have had a brain fart when I typed in the wiring. You got the correct response, a spark, with that wiring.
The motor is a series wound motor. This means that the field is in series with the brush. The configuration that I assumed that you have is that the yellow and red leads are the field leads and that the green and black are the brush leads. Try wiring it this way:
first way
b = +
r = -
g + Y
second way reverse direction
b = +
y = -
g + r
Tom:
You are correct. I can not thank you enough.
Thanks again,
Roy
This message was edited by Merc Cruzer on 2-1-14 @ 8:30 PM
Merc Cruzer
01-29-2014 @ 7:59 AM
I have a 1953 Mercury Convertible.
This message was edited by Merc Cruzer on 1-29-14 @ 8:00 AM
01-29-2014 @ 4:22 PM
Nice car, I love the 53 Mercury. It was the best looking of them all. It was also my honeymoon car.
02-01-2014 @ 9:34 AM
Here is a corrected way to wire the dc motors used in window motors.
This message was edited by TomO on 2-1-14 @ 1:06 PM
02-01-2014 @ 1:09 PM
Corrected attachment.
Merc Cruzer
02-02-2014 @ 6:01 AM
Motor at issue
