EFV-8 Club Forum / General Mercury Discussion / 40 Mercury Wiring
Posted By Discussion Topic: 40 Mercury Wiring
rradar
09-11-2011 @ 3:22 PM
Discovered ignition wire switch wiring that is burnt and not connecting to coil. Car just received from shipper who used a jumper wire from battery to coil to start motor. Question: is it necessary to remove steering wheel to access the ignition wire leads to the ignition switch??
09-12-2011 @ 7:09 AM
No, you can access the wires and switch body from the bottom side of the steering column collar.
The wire going to the coil comes from the resistor / circuit breaker panel mounted on the upper left corner of the interior side of the firewall. The other side of the resistor is connected to the ignition switch.
