EFV-8 Club Forum / General Mercury Discussion / Transmission noise
Posted By Discussion Topic: Transmission noise
BorzoiBob
04-16-2022 @ 1:50 AM
Help please guys .
1947 Mercury station wagon ( all standard ) I had a bad noise at constant speed when travelling , worse the faster you go . Stripped the gearbox and found a bad rear bearing on the mainshaft . Rebuit the box and clutch . All back together and the noise is still there . Not quite as bad and the box is much quieter and smoother . Any help or info greatly appreciated . It has a closed or torque tube shaft .
04-16-2022 @ 10:16 AM
Are you sure the noise is coming from the transmission? It could be caused by something else in the drivetrain like the U-Joint or the rear axle. Even the cable for the speedometer could be the cause.
This message was edited by carcrazy on 4-16-22 @ 10:17 AM
04-21-2022 @ 5:44 AM
BorzoiBob
IS the noise their with the engine running just standing still ?
or only when the car is moving ?
more info is needed to Diagnose the problem,
when you fixed the trans did you use original gears or repros ?
what kind of noise do you hear,?
let us know,
37Ragtopman.Maine
This message was edited by 37RAGTOPMAN on 4-21-22 @ 5:45 AM
sarahcecelia
04-22-2022 @ 4:19 PM
It might be the Ring and Pinion, or a rear axle bearing.
