EFV-8 Club Forum / 1940 Ford Discussion / 6 volt oil sender for 40 Ford
Posted By Discussion Topic: 6 volt oil sender for 40 Ford
Matt
11-14-2022 @ 3:36 PM
need a 6v oil pressure sender with 50 lb rating for my 40 ford, any ideas?
11-14-2022 @ 3:48 PM
did you try SOUTHSIDE OBSOLETE in MINN,
Fred should be able to help 1 507 332 6789
he should have ORIGINAL FORD PART,
hope ths helps 37Ragtopman ,Maine
This message was edited by 37RAGTOPMAN on 11-15-22 @ 8:14 AM
11-14-2022 @ 11:31 PM
If you are not able to locate the oil pressure sender from the previously mentioned source, you may want to contact Yesteryear Ford Parts at 517-676-4416 to see if they have part number 48-9278 in stock.
