wheel cylinders and master cylinder
fortyford |
11-19-2021 @ 2:54 PM
Where is the best place to get brake parts for 40 Coupe?I am just curios if NAPA still has them?I did a search on there site with no luck.I need a good quality wheel cylinders and master cylinder.I don't need no Taiwan or China if possible!
carcrazy |
11-19-2021 @ 5:01 PM
There are many sources from which you can get the brake parts you are seeking. Even though NAPA may not list them, if you work with a competent counter person at your local store, he/she can order the proper parts for you. Other sources are Mac's, C&G, Yesteryear Ford Parts and others. You may have to accept some parts that are made in China.
37RAGTOPMAN |
11-21-2021 @ 11:56 AM
hi I do not know if this is what you are looking for but WHITE POST RESTORATIONS , RELINES your wheel cylinders and master cylinder with brass sleeves, If your wheel cylinders and master cyl are worth restoring , you know these will fit and work, might be the best way to go, they will never rust pit again, hope this helps 37Ragtopman
This message was edited by 37RAGTOPMAN on 11-22-21 @ 6:52 AM
