'40 lower radiator hose / heater hose fitting
sarahcecelia |
06-17-2019 @ 7:23 AM
"Kubes", I got a new heater hose outlet fitting for the lower radiator hose on my '40 convertible. Do you recommend any kind of sealer on that fitting to preclude it from a possible leak, or just fitting it up and tightening it? By the way, I got it from Carpenter and the circumference on the outer piece, that goes under the nut, was too small (and not the same as the old piece) and I had to put it in the vise and "squash" it a little, to get it to match the old one, for a proper fit to the outside of the hose! UNBELIEVABLE!!! The inner piece had the same circumference as the hose.
kubes40 |
06-17-2019 @ 12:50 PM
I use INDIAN HEAD SHELLAC available at NAPA, about $2...
sarahcecelia |
06-17-2019 @ 5:54 PM
" Kubes", Would Permatex Aviation Form-A-Gasket work? I have that on the shelf. Regards, Steve Lee
This message was edited by sarahcecelia on 6-17-19 @ 5:57 PM
kubes40 |
06-18-2019 @ 6:22 AM
I really don't know. Indian Head Sh*llac has been around for decades and is a tried & true chemical for this (and other) types of seal. I use it on all radiator hose connections as an added assurance against leaks.
sarahcecelia |
06-18-2019 @ 10:51 AM
Thanks, Mike, For 2 lousy bucks I'll get the "Tryed and true" Indian Head.
Regards, Steve Lee
