U-Bolts
Stanley |
01-03-2017 @ 6:23 PM
Looking for a supplier for original type rear spring U-Bolts to be used on a 1940 Ford Convertible. This rear spring has 10 leaves. Thanks, Stanley
kubes40 |
01-03-2017 @ 7:02 PM
Stanley, The U-bolts you seek are not reproduced. However, they are not all that rare either so you should be able to locate a pair without too much trouble. I might suggest Dennis Carpenter's NOS parts department as well as Mike Driskell. Mike can be reached through eBay. His seller's name is 1935fordtn. Carpenter's can be reached by phone, 704-786-8180 Let me know how you fare with those two suppliers. Hope this helps, Mike "Kube" Kubarth
Stanley |
01-15-2017 @ 6:05 PM
Mike, Thank you for the two leads for U-Bolts. I started with Dennis Carpenter and they have NOS U-Bolts in stock. Doug was very helpful in making sure that he would send the correct U-Bolts . They arrived and are the correct U-Bolts. Thank you for your help, Stanley
kubes40 |
01-17-2017 @ 7:17 AM
Glad that worked out for you! Mike
