1950 F2 Vin# - Need Help
The Red F2 |
10-17-2022 @ 4:00 PM
Hello Folks, Thanks for allowing me to join. I have a few Fords. I just bought a 1950 Ford F2 without a title and have some issues finding out the vin details of this truck. If you can reccomend or help out in anyway, TIA!!! *98RD*397522*AT
truckdog62563 |
10-21-2022 @ 7:29 AM
Your Serial number shows the truck is a 1950 F-2 V8 built in Atlanta. The below FTE thread gives a lot of detail, but basically the 1949 numbering sequence was carried over to the 1950s. Thus the 98 of 1949 remained in 1950. The R is V8, the D is F-2, and the unique 397522 places the truck squarely into the 1950 sequence. There will also be a cowl stamping that will allow the guys on FTE to tell you build date and color. I’m not so good on that task. Stu https://www.ford-trucks.com/forums/423340-1948-1960-1949-1950-vin-cut-off.html
Stu McMillan '47 Tonner Marmon Herrington V8 '52 F-3 Marmon Herrington I6
alanwoodieman |
03-10-2023 @ 3:51 PM
the VIN on the frame is front right side (pass) of frame towards the front clean off frame to verify, there should be a matching info tag on the inside the glove box door
