EFV-8 Club Forum / 1932 Ford Discussion / 1932 stock coupe radiator cap position
Posted By Discussion Topic: 1932 stock coupe radiator cap position
f1ford48
01-05-2018 @ 4:28 AM
which is the correct position of the 32 cap, with the higher part of the'' wing'' to the front or rear?. reason I ask is for a scale model I am building-I have seen many pics with it mounted both ways Thanks
01-05-2018 @ 7:33 AM
Here is a link to the sales brochure for the 1932 Ford models. Look at them and make your decision.
http://www.oldcarbrochures.com/static/NA/Ford/1932%20Ford/1932%20Ford%20Full%20Line%20Brochure/index1.html
3w2
01-05-2018 @ 7:27 PM
The highest point should be at the rear of the cap. As a running change, Ford altered the radiator spout and cap so that it could not be installed backwards.
f1ford48
01-06-2018 @ 1:46 AM
thanks for the info-the brochure tells all
