Seatbelts in a 34 Fordor
dennis |
01-22-2010 @ 12:39 PM
I want to install seatbelts for the front seat in a Fordor. My concern is how to deal with the seat frame whch seems to be in the way exactly where I need to bolt to the floor plan. Can anyone give me some advice on how they did it? Thanks,
nelsb01 |
01-22-2010 @ 1:24 PM
I dont have 1934, but in my 1949, I have the seat molding at the bottom of the front seat. I just measured back from that and attached the belts there. The side of the seat belts I did the same. Point to consider: when drilling through the carpet, mark you spot and then use a exacto knife to cut the carpet. Cut an X about 1/2 inch -- that will stop the drill from catching a carpet fiber, and causing a run. Also, make sure you use the biggest and thickest washers you can find. This will help disepate any 'force' over the floor plan that is exerted on it by the belts.
Terry |
01-23-2010 @ 8:45 AM
I had the same pbm in my 36. I drilled a series of holes in the seat frame and with a hacksaw blade and file was able to make a slit wide enough for the belt to get through. It was tedious, but after 4 such slits in the seat frame for 2 seatbelts, I was able to get the belts thru and attach them to the flooring. The slits were made where vert and horiz parts of frame met. Terry
supereal |
01-24-2010 @ 10:59 AM
I would expect slits to abrade the belts and make them unreliable and dangerous. We usually mount the lower anchors on top of the carpet or mat, and place a bolt thru the floor pan, and then use large "fender" washers on the lower side of the pan. Don't fasten to the frame, as the body may shift in a collision, causing the belts to become a dangerous noose.
