Anyone know a good engine rebuilder
-- page:
1
2
johnaq |
12-07-2024 @ 2:55 PM
Anyone know a good engine re-builder in the NY area. I am about 35mile from the city
mfirth |
12-07-2024 @ 3:35 PM
Not familiar with this one, but it was posted on The Ford Barn; Mark Moriarty (Valve-en blocks) Warsaw, NY 14569, 1-585-786-2876, email: mkansas32@yahoo.com You might try posting this on "The Barn". Good luck. Mike
nelsb01 |
12-07-2024 @ 5:26 PM
In NY.............give Mark a call. If he can't do it, he would know who can.
johnaq |
12-07-2024 @ 5:30 PM
Warsaw is about 6 hours away. I will give him a call
carcrazy |
12-07-2024 @ 7:31 PM
Try this engine rebuilder listed as being in NY. The Babbitt Pot Zigmont G. Billus 1693 St Rt 4 Fort Edward, NY 12828 518-747-4277
1942deluxe |
12-08-2024 @ 5:30 AM
I sent Mark an email several years back and at that time he told me he was pretty well retired.
johnaq |
12-08-2024 @ 6:48 AM
Ok, here's another question. I may have located a replacement engine. It is older and has the old style distributor. Can I install the timing cover from mine and use the modern distributor?
carcrazy |
12-08-2024 @ 7:37 AM
Why not just use the older distributor? Once properly set up on a distributor machine these older dual point fully centrifugal advance distributors are essentially bullet proof for 20K miles or so. The later, 1949 and newer, distributors use a fully vacuum advance system which requires a venturi vacuum source at the carburetor. If you change carburetors or go to multiple carbs, your engine won't receive the proper spark advance curve and will be down on fuel economy and performance. The later distributor requires a drive gear on the front of the camshaft to make it function.
RIrover |
12-08-2024 @ 6:55 PM
I used j&m in Massachusetts. Top first class work
regards, David B Campbell
johnaq |
12-09-2024 @ 4:54 AM
Wow that is beautiful! Can I ask what he charged?
