EFV-8 Club Forum / General Ford Discussion / 1939 Ford Deluxe Coupe window regulator question
Posted By Discussion Topic: 1939 Ford Deluxe Coupe window regulator question
sssraj
09-22-2022 @ 8:28 PM
Could someone have a diagram that shows where the Ford window regulator stop screw A-3-14 goes. My Window regulators were missing several parts including the Ford window channel replacement roller assembly 78-702148-K and I think this stop screw.
I installed two new Ford window channel replacement roller assembly 78-702148-K. I order the new stop screws as well but fail to see where the stop screws are located on the regulator. The first picture shows the stop screw.
thank you
This message was edited by sssraj on 9-23-22 @ 2:35 PM
JayChicago
09-24-2022 @ 7:49 AM
If the same as the ‘37 I have experience with:
The stop screw goes into a threaded hole near the center of the lower glass channel. There is a gap in the lower glass channel that lets you insert/remove the regulator’s slide pins in the lower glass channel. The stop screw is installed after slide pins are in the channel, stops one pin from traveling all the way to the gap so pins do not fall out.
sssraj
09-24-2022 @ 11:36 AM
Thank you very much I will take a look.
