37 Ford Headlight
37fordguy |
09-21-2020 @ 12:27 PM
Can anyone tell me how to change the headlight bulb--the ring and lens do not come off after removing the bottom screw.
1937sedandelivery |
09-21-2020 @ 1:44 PM
I recall the similar situation on my 37. The lens cover (ring) snaps in place due to four little tabs around the outside of the bucket. See attached jpeg picture. It takes some coaxing, but what i do is give a good tug on one side of the cover to break it loose. One time I actually had to use a screw driver to pry it off. Just be careful to not mess up the fender paint surrounding it. I have lots more pics of the entire headlight assembly if you are interested. It is in a multi-page pdf file. gregg
3w2 |
09-21-2020 @ 5:06 PM
Use an old credit or debit card against the adjacent painted surface and you won't chip the paint when you pry.
37fordguy |
09-21-2020 @ 6:17 PM
Thanks guys--got an L shape scr*ped under the bottom edge and gave a couple good yanks without any damage-whew never again.
TomO |
09-22-2020 @ 7:19 AM
Buy some nylon pry tools, they won't scratch the paint. I use them to remove my hub caps, so i don't have to keep touching up the wheels. They are available from Eastwood and online from other suppliers.
