EFV-8 Club Forum / General Ford Discussion / original 34 V8 motor. I need to buy one. I hear i
Posted By Discussion Topic: original 34 V8 motor. I need to buy one. I hear i
logan238
08-18-2020 @ 1:58 PM
I need to buy a 34 to 36 motor for my cabriolet. I'm in utah ,know of one/
CharlieStephens
08-18-2020 @ 6:21 PM
Placing a wanted ad here (https://www.earlyfordv8.org/classifieds.cfm?t=Wanted&c=Parts), on Fordbarn (https://www.fordbarn.com/forum/forumdisplay.php?f=18) and on HAMB (https://www.jalopyjournal.com/forum/forums/wanted.30/) will probably turn something up. Good Luck.
Charlie Stephens
08-19-2020 @ 11:05 AM
I'm willing to bet placing a wanted ad in the actual "wanted" section may work even better.
08-20-2020 @ 10:05 AM
In addition to Kubes comment above if you want a 33-34 engine look for that. The 35-36 engines are different.
dann
11-10-2020 @ 6:43 AM
I've got a complete running 21 stud 36 flathead,with mallory 12 volt dist. here in ohio if interested call dann at 330-440-5412 oil pan to air cleaner
11-10-2020 @ 10:01 AM
hi
are you going for show, for points, or for a driver,
cause a late 36 has insert bearing,
and 37 engines also insert will bolt in with no problems,
you have to use plates on where the 37 water pumps would be and use 34 heads,
but when done will look like a 34 engine,
earlier engines were Babbitt bearing, not that is bad,
I have a 37 engine that needs 3 sleeves ,
hope this helps,
37Ragtopman Maine,,,,
