Squeaking rear spring shackles
-- page:
1
2
Gordon T |
07-11-2020 @ 5:19 PM
Rear leaf shackles are squeaking and squacking, GB states that no lubrication is required. Just what can I use without damaging shackle rubbers? Thank you!
carcrazy |
07-11-2020 @ 8:48 PM
Use some silicone spray on them.
51504bat |
07-11-2020 @ 9:44 PM
Garage door lubricant. Garage Door Lubricant is a silicone-based lubricant that leaves a tack-free film that won't accumulate dust and dirt. Stop squeaks.
This message was edited by 51504bat on 7-12-20 @ 12:17 PM
40 Coupe |
07-12-2020 @ 4:24 AM
What is GB?? There are a couple of different shackles what type do you have? Metal shield one piece original style or the plastic style two piece inserts?
Gordon T |
07-12-2020 @ 6:05 AM
GB is the Green Bible and the springs/shackles are original, sounds like a chirping bird. Gonna give the silicone spray a go, thanks for the replies.
This message was edited by Gordon T on 7-12-20 @ 6:07 AM
Gordon T |
Thank you
trjford8 |
07-12-2020 @ 7:34 AM
51504bat. The second part of your comment is totally uncalled for. I suggest you edit your post and remove it
JayChicago |
07-12-2020 @ 10:10 AM
Trjford8 I think that line is pretty funny. I might even use it some day. But not in print! I agree with you, its inappropriate here. Sophomorish. Like the big plastic testicals I sometimes see hanging below the back of pickup trucks. Chuckled a bit first time I saw that, but most of us stopped doing stuff like that when we got out of high school.
This message was edited by JayChicago on 7-12-20 @ 10:26 AM
51504bat |
07-12-2020 @ 12:20 PM
51504bat. The second part of your comment is totally uncalled for. I suggest you edit your post and remove it That is or was my signature which I have since deleted.
50CaPU |
07-12-2020 @ 3:53 PM
Have a similar problem with a car i recently bought..... an older restoration. Plan to remove the springs but wanted a temporary remedy. I used Kroil penetrating lubricant and have reduced the spring, shackle, and shock link squeaking until i can disassemble and lube properly.
Tim Downtown, Ca
