'34 Fuel Pump Push Rod Bushing
Amigo4 |
04-02-2020 @ 4:43 AM
Does anyone have a suggestion on how to remove the fuel pump push rod bushing from the block? The engine is in the car and I would really not have to remove the manifold. Any ideas would be helpful. Thanks, Dave
ken ct. |
04-02-2020 @ 5:27 AM
They are almost impossible to remove with engine in car. Unless there complety worn out leave alone. Even new ones are a very sloppy fit in reallity. Its the umbruler that stops most of the oil from coming up into the valley chamber. ken ct
40 Coupe |
04-02-2020 @ 5:31 AM
It is extremely rare one has to replace this bushing. Is the bushing worn through? They are usually very loose. The hole can be packed with paper or cotton and a tap run inside and then a threaded rod with a spacer and nut used to pull the bushing out.
ken ct. |
04-02-2020 @ 7:59 AM
If you don't mind metal chips down in your engine go ahead and tap it. You will get some out with a greased tap BUT NOT all of them. IMO, ken ct
Amigo4 |
04-02-2020 @ 9:38 AM
Thank you for all the insight. I will just leave it well enough alone. Thanks again, Dave
ken ct. |
04-02-2020 @ 1:32 PM
Smart move. ken ct
